HELP! Quick question?
That looks alot like one of the locator pins for mounting the ABS distribution block on my Z06. There is one on each side of it. I know your car is an F-body, but maybe it has a similar set-up. Hope this helps
Jimbo
Jimbo
Its the abs mounting bolt... there is one on either side of the abs block, the smooth side slides into the block and the threaded side slides down in a slot on the top of the mounting bracket then you tighten the nut down to hold it in place.
