Anybody here got a Lunati 408 stroker?
Old 10-22-2003, 11:04 AM
maddboost's Avatar
Default Anybody here got a Lunati 408 stroker?
I was wondering if anybody heres got a Lunati 408 stroker? I threw a rod and am replacing the engine and the pice for the 408 stroker I got isnt much more than a forged 346. I plan on having a local engine builder assemble the engine for me. Besides what comes with the kit is there anything else you need? It seems like a big stroke most of the larger cube motors ive seen have been iron blocks.
Phil
Old 10-22-2003, 11:19 AM
TApimp's Avatar
Default Re: Anybody here got a Lunati 408 stroker?
we have a 408 in two of our cars. both are iron blocks.
come with. rods ,bearings, crank, pistons, rings. all u will need is machine work and assembly
Old 10-22-2003, 11:31 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,090 Likes on 718 Posts
What is the Lunati 408 kit?
Old 10-22-2003, 11:35 AM
gator's 99TA's Avatar
i would assume this is a stroker kit for the iron 4" bore motor?
Old 10-22-2003, 12:53 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
I've done a couple 408ci engines in the last 6 months. Its a 4.030" bore, 4" stroke Lunati kit. I don't use the whole Lunati kit anymore since the pistons are 13cc dish and if you deck the block, the pistons come way outta the bore. They are already setup for .007-.008 with a 9.240 deck height, and since most 6.0L blocks need to be squared for a performance build, sometimes up to .010" needs to be machined off. If .010" needed to be removed that would leave the piston at about .018" above the deck at TDC.
Quick Reply: Anybody here got a Lunati 408 stroker?
