rod bearing install
Old 03-27-2009, 10:06 PM
pdasterly's Avatar
Default rod bearing install
does the oil hole go on top or the bottom(facing the oil pan) thanks
Old 03-27-2009, 10:37 PM
Randy WS6's Avatar
The rod bearings dont have holes in them, unless you have rod bearings for aluminum rod,They have a hole in the bearings for the dow pin that supports the bearing. The steel & stock rods dont have any type of hole in the bearing that ive ever seen.
Old 03-28-2009, 03:20 AM
pdasterly's Avatar
Old 03-28-2009, 09:20 AM
Randy WS6's Avatar
Those are for aluminum rods, Take them back , There should not be a hole unless your running aluminum rods.
