amp works with 1 sub and not 2
Old 03-27-2009, 10:45 PM
StylinZ's Avatar
Default amp works with 1 sub and not 2
So here's my setup:
Audiobahn a8002T
200.0 Watt - 4.0 Ohm - 2.0 channel(s)
400.0 Watt - 2.0 Ohm - 2.0 channel(s)
800.0 Watt - 4.0 Ohm - 1.0 channel(s)
2 10" JL 10w-1
4 ohm single voice coil
125watt RMS
Ported box
Now that all of that is out of the way. Here's way happens.
hook each sub to each channel and the power light will continually fade out (along with sound) After a few times of this it'll eventually cut off and then turn back on and the sub will shoot out and then th protection light will come on.
hook 1 or 2 bridged............ same thing..
hook 1 to 1 channel and it works perfectly.
Any suggestions?
TIA
Old 03-28-2009, 01:17 AM
Silver Rocket's Avatar
how are the subs wired?
what kind of voice coil? 2 or 4?
you are proble running too low of a impedence and thats why the amp is going in and out of protect
Old 03-28-2009, 08:42 AM
John2005's Avatar
It says 4 ohm single voic coil above so i am guessing he should be fine either way if he wires them bridged or not since it would be a 2 ohm impedence when bridged. So I don't see that as the problem, it could be the amp or a bad ground or power going to the amp.
