coil pack question
coil pack question
im having a cylinder misfire and after scanning it the codes thrown were translatedto this multiple cyl misfire
po351- ignition coil a
po353- ignition coil c
po355- ignition coil e
po357- ignition coil g
nowim guessingonewhole side is out for what ever reason ,justput in new plugs thought that was it before scan , so is it one side and if so which side is it , it only does it at cruising highway speed , not at idle so which side is a,c,e,g ? please help and thanks imstaying up in my garage all night till i find out so i can get another set and if you would know why one whole side would go out at once please all your input , thanks im standing by
Check your main connection from your wiring harness to your coils. It is between number 3 and number 5 coil if i'm not mistaken. If its been unplugged before it may have come loose if you didn't put the safety latch back in place.
I had that problem once, and narrowed it down to the main plug to the coils. Water had gotten in there, and there was buildup from moisture. The easiest way to determine if it is the connection, or not, is to switch the coils from one side, to the other, and see if you still get the same codes, or if it switches sides.
