Refresh
Refresh
My LT1 is getting some high mileage on her but doesn't burn a drop of oil. And Ive been thinking of refreshing the internals. What do you guys recommend I get to do this. I know the obvious stuff like a ring set, rod/crank bearing set, camshaft bearings and a complete gasket set but what about all the little stuff that might need to be replaced?
I'm not doing a entire rebuild just refreshing some of the internals. Basically replacing all bearing and seals and any part that's worn out. I guess I'm basically asking are there any parts like valve guides, valve seals and the like that might need to be replaced. I'm trying to getting things put together before I tear down into the engine.
