tuner/Progammer?!
Old 03-28-2009, 09:08 AM
z2895's Avatar
Default tuner/Progammer?!
hey, i just rebuilt my 1995 camaro z28 with the lt1. Its just a little over stock HP, didnt do much. just honed it and decked the block. Over the winter i just put in a ford 9 inch with 411 gears. my question is, with the new gears my mph is is screwed up and i can only go like 90 mph because my speedo is going 115. so it hits the speed limiter. Were do i get this tuner or programmer for the odb1. I tried looking around, couldnt find much, help me out thanks
Old 03-28-2009, 10:04 AM
Silver Rocket's Avatar
hypertech makes some good programmers
Old 03-28-2009, 10:11 AM
multmigs's Avatar
Cool
Yeah get a $300 plug in tuner which is generically designed not for your particular car..
Or you could just get a PCM reflash specifically set up for just your car for half that much.. Did you try www.pcmforless.com??? Or www.pcmperformance.com???
Old 03-28-2009, 10:36 AM
donkey mule's Avatar
Why not just get Madz28 (Madtuner) to get you an email tune. I have used his tuning 5 times and it has been great every time.
Old 03-28-2009, 10:47 AM
z28rob18's Avatar
how does the email tune work? do you just need the cable and he sends you wat you need to do or you need the software as well?
Old 03-28-2009, 12:27 PM
J-13gtp's Avatar
Personally Id go with the Hypertech programmer. Its a bit more expensive but you can change a few things with it. Ive got one and satisfied with it. Look on ebay and you might get lucky and find a used one there.
Old 03-28-2009, 12:31 PM
bombebomb's Avatar
Hand helds are a waste of time and money, get a mail order for half the price (or less) and get more done.
Old 03-28-2009, 12:33 PM
myltwon's Avatar
the only tuner you should ever using is a human being
Old 03-28-2009, 04:12 PM
multmigs's Avatar
an email tune requires you have a laptop and the cable that connects from that to the underdash port, plus the software which is usually free to load the PCM file which you buy from a tuner from your laptop to the car's PCM.... you can also do real time datalogging like this and help to refine the tune for your specific mods by emailing this info to the tuner...
Old 03-28-2009, 05:01 PM
RamAir95TA's Avatar
No one here should ever use the Hypertech programmer. Garbage.
Old 03-28-2009, 06:20 PM
gregrob's Avatar
Get the cable!!! Well worth it. A lot faster and cheaper to get tunes that way and you will be able to see what is going on with your car, scan codes if there is a problem, etc!!!
I got mine from www.aldlcable.com and the guys over there is awesome and the cable works great.
Old 03-28-2009, 11:01 PM
shbox's Avatar
The Hypertech would be fine if all you needed to do is change for the new rear gears (as long as you bought a used one for ~$50... and don't even think about it for performance gains). But for anything more than that, you should consider a mail order tune or DIY tuning.
Old 03-28-2009, 11:32 PM
FbodyFreak's Avatar
I say screw the hand held tuners, all of them. Diablo sport, hypertech,ect...
they are all trash. My personnal opion is ed wright custom tune from fastchips
He specializes in lt1's. His tunes are GREAT too. He does custom tunes for your
Setup, go to fastchips.com and check out the custom tune order form.
Quick Reply: tuner/Progammer?!
