M6 to a Th400
M6 to a Th400
hey guys i just installed my th400 car was a M6 ...the car has a 5200 stall trans brake and 2 step , my ave with the 6spd was 1.55 60ft on mt 275 radials and went 10.60's ave @ 129 mph
a lot of weight came out since last year car is just under 3000lbs rest of my mods in my sig ....hoping for a 10.0 pass or better this year , oh yeah going to a full slick for the upcoming year
here is a short test video going down the street but the car is a completely dif car ! cant wait to come off the trans brake
http://www.youtube.com/watch?v=Y8D8NICeMUU
I did the same swap, you will never regret it. Sure I miss bangin gears, but launching off the brake at 5600 rpms, cutting 1.3 60' times is a lot more fun. The car sounds awesome btw.
Well I run a 28" tire too. When I was a 6 speed I was crossing the traps around 7100, but with the th400 I get a little bit of converter slip. You have to account for that too, and there's nowhere to go when 3rd gear is done. Regardless of nitrous or n/a, our trap speeds are similar so the same thing might happen to you. Hopefully it works out for you though.
and yes i went to the darkside lol im tired of breaking **** with the m6 lol
Car is going to fly! You may loose a little bit of MPH but the ET will pick up big time. I run 26 inch ET Drags and have run the times in the sig. I think with the big stall and the 28 inch tires you will be fine. When I ran the 10.25 at 129.5 I did not hit the rev limiter which is set at 7,200 RPM's!
Good luck with it.
N2
