Got a diablosport tuner, doesnt fit.
Old 03-28-2009, 07:09 PM
antsls1's Avatar
Default Got a diablosport tuner, doesnt fit.
I bought a diablosport tuner for my car a while ago and i just now figured i would ask bout it. i own a 94 camaro that used to have a 3.4 v6 in it but the guy i bought the car from converted everything over to an ls1 from the front bumper to the rear tail lights. i mean everything but obviously not where this tuner hooks up. it looks like the wrong plug but it is the correct tuner. does the conversion have anything to do with it and can i even put a tune on the car. a friend that has a different plug on his car and he has a 02 camaro LS1 and he said somethin bout i think he said od1 and od4 or something like that. can anybody help me?
Old 03-28-2009, 08:06 PM
y2khawk's Avatar
Yep, the obd1 cars have a rectangular connector while the obd2 cars have a V shaped connector.
If it's wired properly with the PCM swap and the PCM is programmed correctly, the predator will have no problem reading and installing the tune. But, you will need to replace the underdash connector with the proper obd2 style.
