new fuel pump..motor runs with low power ..
Old 03-28-2009, 08:47 PM
jugz ss's Avatar
Default new fuel pump..motor runs with low power ..
whats up...first off my writing isnt so good but im just here to get some help and im not sure if this is the right place to post but here it goes
.my car is a 2002 ls1 camaro
well i had this problem where my car would run with low power..i looked into it and it wasnt trowing any codes so i changed fuel filter,air filter,and nothing so i got a new fuel pump..the car still runs with low power *** if werent geting enough fuel..i checked pressure at the rail..its at 60psi
i have no idea where to look next..the car has new filters,plugs and wires and fuel pump..any help will be good...thanks
Old 03-29-2009, 08:42 AM
Old Geezer's Avatar
Scan the system, and see if there's some info to be had ???
Original exh system, w/ cat??
Throwing parts at it won't do much good.
Old 03-29-2009, 05:40 PM
jugz ss's Avatar
well i already scanned it...theirs no codes coming out other then p0106 which is for the air pump that isn't on anymore
no its not original exhaust...i have lts with ory....front 02s are good...rears are deleted..
the reason i threw all the parts was because i bin searching here and around..and those where all possible causes so i just got trough all of them just in case but no fix
Old 03-29-2009, 06:07 PM
Old Geezer's Avatar
Ok. So have you run any datalogs?
When you say "low power", is that seen when on the dyno, or is this a "butt dyno" test?
You say the FP is 60# @ the rail. Is it still in that area when you run it under high load? [FP gauge on the W/S, and drive it.]
If you have the required FP and the engine is running with no load,[very low flow required], does not mean the pump/system is keeping up w/ hi demand.
Old 03-29-2009, 06:44 PM
98Camarod's Avatar
Clogged cats, clogged filter? Did it just happen out of no where?
Old 03-30-2009, 01:40 PM
jugz ss's Avatar
datalogs? im not very familiar with that
no not on the dyno....the butt dyno...its a big power difference and hesitation
no i havent checked psi on a high load...ill check that today
Old 03-30-2009, 01:43 PM
jugz ss's Avatar
no i have no cats...and you mean fuel filter?..its new....air filter?..its new too
it actually happened after i pressure washed my engine bay
Old 03-30-2009, 01:50 PM
jugz ss's Avatar
bump!!
for any help..
Old 03-31-2009, 08:03 AM
Old Geezer's Avatar
"it actually happened after i pressure washed my engine bay".
Well then, I'd start with an air supply, some PLASTIC SAFE contact cleaner, and clean, dry all electrical connections. Could be, you have pushed water into some plugs....
Old 04-02-2009, 06:03 PM
jugz ss's Avatar
ok..thats bin done..and it still runs the same
i actually drove the car for a bout 20 min and it just went back to normal out of no where...but then once i turned it off and got on it again...it started acting up again
im at the point where i have no idea where to look next
i already checked and cleaned injectors as well...
i checked many possible causes and nothing
Old 04-02-2009, 06:04 PM
jugz ss's Avatar
bump!!
for any help
