383 Internally balanced, will stock fly wheel work
Old 03-29-2009, 12:28 AM
qnitro's Avatar
Default 383 Internally balanced, will stock fly wheel work
I have a new 383 LT1 stroker...It is internally balanced set up... Will the stock Fly wheel off my 97 SS work??
Old 03-29-2009, 12:31 AM
Village Troll
SS RRR's Avatar
Yes it will. Just as long as you take it to a machine shop and get it neutral balanced. Don't even think about putting it on until that is done.
Old 03-29-2009, 12:33 AM
qnitro's Avatar
Awesome... Should I just buy a new one?? or is the stock one worth balancing..what would it cost you think??
Old 03-29-2009, 12:38 AM
Village Troll
SS RRR's Avatar
That depends too. If you are going to use the original clutch and the clutch/PP/flywheel are in good shape then sure. However if you are going to use a new clutch/PP then it is definitely worth the cost to get a new flywheel or at least get the one you have now resurfaced and rebalanced.
Old 03-29-2009, 12:46 AM
qnitro's Avatar
thanks for the info... Will buy a new one... Now I need to get the bolt out of my crank thats stuck on my Firehawk...(its my other LT1 car)
Old 03-29-2009, 01:32 AM
fergymoto's Avatar
The Spec billet steel ones are nice, they have a removable weight for internal/external balance. It is held on by 3 bolts.
Old 03-29-2009, 12:07 PM
94Z28rag's Avatar
That's what I got when I went to a Spec Stage 3. Feels great.
Old 03-29-2009, 12:35 PM
Chevyguy358's Avatar
Yea when I threw in my 383 I forgot about this until it was almost completely ready to fire. Luckily I remembered however had to pull the tranny. I had mine balanced locally here and I believe it cost me around $50
Quick Reply: 383 Internally balanced, will stock fly wheel work
