Flat Tire;
Flat Tire;
So yesterday night I went to the track and after the first pass one of my slicks Managed to pick up a screw that was somewhere in the return road or staging lanes(I know my local track sucks). So had to change all my tires again and could only race once more. My Q is should I be carefull once I get this flat tire issue handle, specially when doing a burn out that I put lots of heat to the tire? Am I the first one to get a Flat Slick????
Iv'e done it for two test and tunes while waiting for the new tire to show up. It's not recommended and I even had to sign a release when I had it fixed, I **** you not. LOL When they saw what they were going to fix, they said you know this is a bad idea right? I'm like yeah, but I only get a few chances a year to hit the track.
And here's another news flash, if you ask them nice, (T&T) they will let you make a single run, as in no one in the other lane. But heah, you have a nice day.
I've plugged a street radial before... Slicks/et streets aren't a good idea though.
BTW you should never replace one slick at a time... This can cause all kinds of problems (if one is worn more then another) and cause alot of launching and other problems... One tire shorter then another equals driving in circles... ok not that bad but you get the idea.
First race of the year last season, I ran over a rock and poked a whole in one of my brand new ET Streets. I ran up to the parts store for a plug to try and get through the rest of the day, that didnt work, got ripped out in the burn out. Made it down the track just fine with a slow leak, when I pulled around, I checked for the plug, and it was gone.
Ended up finding a bias-ply patch, used that and didn't have a problem for the rest of the life of the tire. Granted I go through a set of ET Streets every 2-2 1/2 months.
we've patched/plugged a slick at work (sullivan tire, a big chain franchise tire/everything shop) it was for a supermodified for circle track racing... i dont see the harm in in just make sure its a quality patch/plug combo... anyone else know what im talking about?
Okay As promised I'm getting back to you guys with the anwers from the manuf themself (MT)
here the e-mail that I sent and the response that I received. Kind of comfusing but basically not to use it again..
We recommend throwing it out as it can be patched or anything and to
dangerous so we recommend getting a new one.
Thanks,
Shaun Sparks
Mickey Thompson Tires & wheels
Technical Support
PH330) 928-9092 EXT:3155
Direct Line330) 686-3555
FAX330) 928-0503
-----Original Message-----
Sent: Monday, March 30, 2009 9:58 AM
To: MT Tech
Subject: Flat Slick
Good Morning:
The reason I'm writing is because the other night at my track one of my
slick MTs managed to grab a screw that was somewhere in the return road
or staging lanes. Now I would like to know what is the best way to
aproach fixing this to a safe operating tire again. I have been
emphasised not to plug it. What would you recomend???
Thank you
Thanks,
Shaun Sparks
Technical Support
FAX330) 928-0503
To: MT Tech
Subject: Flat Slick
Good Morning:
Thank you
