my set up, is this ok? need some advices, (pics)
hi all, i posted some pics and questions on my other thread, but havn't got the answers (to that question)
i am finishing to mount my solenoids and lines, i had an idea and layed the lines under the fuel rails, and under the solenoid,
my questions are, is this allrigth? is it ok to bend the hose that much? is the angle not to tight?
i took some pics today, that i will post tonight,
but here is the angle that i am most afraid that is to "tight"
is this allright? n2o line
also i am thinking about to let the purge blow out f one of the holes behind the grill, to do that i will have to bend the line pretty much, is that allrigth?
i will post better pics tonight, that show more, both w/purge, and the fuel line
best regards!
best regards!
here are the newer pics, is this alrigth?
n2o+purge, and the line
the line
is the filter alrigth like this?
purge,
fuel noid, the line question is also about the fuel lines, rather tigth angle on both sides
spread your knowledge
the line
purge,
look fine why not mount the filter right after the bot rather than that far up front.
filter is a 4an as well as the bottle nut in mostcases little less clutter under the hood
you should spring for the all in one cylinderhead mounting bracket look in my for sale thread you can see what it looks like will make your install real clean
https://ls1tech.com/forums/lsx-parts...uner-prog.html
Everything looks fine. As long as none of the lines are kinking, you shouldn't have any problems.
I'm gonna agree with stangeater, I'd put the nitrous filter back near the bottle as opposed to under the hood.
-Will
-Will
thanks for the tip, i will move the filter near the bottle i just saw some car here on ls1tech that had it there
i'm glad it's okey to lay the lines like that, i think it looks kinda nice for a newb set up
