diff between ls1 and ls6
i have an 02 camaro and the block casting number is 12561168
is it an ls6 block or ls1?? i've read the diff between them but can u tell by looking? everything i can find gives me no answers.
Location: Your girl's back door giving her the long stroke while you're at work
ALL 01-02 LS1 cars had an LS6 intake
Difference between the two(LS1 motor/LS6 motor) are block, heads, cam and a few other little things
That's the casting number for the LS6, What you have is an ls6 block w/ ls1 internals, cam, and heads. The ls6 blocks are all a dark grey and MOST ls1's are a light gray. The diff casting pros. causes a color differance. Some later ls1's were cast in the same plant as the ls6 so they are dark colored also.
I bought an 02 take-out that has the LS6 block.
