flowmaster merge
But with the answers people are giving, I would conclude that no one makes a 3" In and 3" Out. Am I wrong? Can anyone answer the original question? I am curious as well if a 3" In and 3" Out can be had.
It does seem strange but throw something like this on there, http://store.summitracing.com/partde...5&autoview=sku
Again I'm assuming that the double end side of the merge is the 3" and the single side is 3.5" ? That would put this at approx. 3' long though, which might hamper the ability to have a muffler in the I-pipe.
magnaflow makes a dual 3" single 3" out y pipe you can find it on summit http://store.summitracing.com/partde...5&autoview=sku
If your goin to do head/cam in the future u want to get the flowmaster 3in 4in out. Because the extra velocity from ported heads will need all the 4 in piping to merge, then into a 3in exhaust. Pat G picked up 20 rwhp by doin this in his 500 rwhp recipe.
https://ls1tech.com/forums/generatio...heads-cam.html
Right here
http://store.summitracing.com/partde...5&autoview=sku.
But use this only if u are gettin heads and cam. It can be used for cam only but will benefit better with Ported AFR Heads.
So you are saying we should use this 3" into 4" merge and then what...use a reducer to go back to 3" for the intermediate pipe? I wonder what the benefits of a quality 3 inch y-pipe using this 3" into 4" Flowmaster merge and then into say a 4" mufflex catback would be on a H/C car with specs like mine below.
