Cranks sputters but no start
Old 03-29-2009, 07:01 PM
jojomanx's Avatar
Question Cranks sputters but no start
Tried to start my ls1 and it just sputters.
All injectors have 12v, coils have spark and Fuel spits out of the schrader valve.
New o2 and crank sensers.
What did I miss?
Old 03-30-2009, 09:38 AM
HDNVALLEY's Avatar
That's the way mine acted when the fuel pump went out. Even though fuel comes out the schrader valve it may not have the pressure it should have. Check the fuel pressure to be sure.
Old 03-30-2009, 08:56 PM
NonGoggleGuy's Avatar
I agree. If fuel pressure is good (around 40psi), check compression in all cylinders.
Old 03-30-2009, 08:59 PM
jojomanx's Avatar
Thanks guys but I just put a gauge on it and the pump is putting out 90+ psi and holding 80 psi when off.
Hmmm!
Old 03-30-2009, 09:01 PM
jojomanx's Avatar
By the way its a newly built LS1 with Lunati cam, port and polished heads w/LS6 piston and rods. 0 miles on it.
Old 03-30-2009, 09:06 PM
Sorry, mis-type. 55-60psi.
Old 03-30-2009, 09:07 PM
Could be a timing issue.
Old 03-30-2009, 09:15 PM
jojomanx's Avatar
thats what I think.
How do I go about trouble shooting the timing??
check my pictures
Old 03-30-2009, 09:24 PM
jojomanx's Avatar
Yesterday I replaced the crank sensor.
Im pretty good with electronics so hit me up with some troubleshooting tips!
Old 03-30-2009, 09:36 PM
With electronic ignition, you'll need a real-time scanner to see the timing advance/retard.
As far as I know (not too much about distributor-less ignitions), as long as you line up the crank & cam at TDC, the computer should take over with the spark advance. If you're mechanically out of time, the ECM will be all kinds of stupid.
I would put a compression gauge in cylinder 1, and make sure the crank lines up at TDC on the compression stroke.
Old 03-31-2009, 03:39 PM
jojomanx's Avatar
TDC on pston one should have both valves closed to see if cam is set right.
Spark on the other hand will be tricky.
Is there any other way?
Old 03-31-2009, 03:52 PM
Spark is uncontrollable without a scanner. It is completely controlled by the PCM.
What I can tell you is that if TDC of cylinder 1 lines up with the TDC balancer mark, there should be no more than about 10 degrees of play in the balancer either way - this checks the tightness of the cam chain.
If TDC of cylinder 1 & the balancer don't line up, your engine needs to be taken apart and re-timed.
Old 04-01-2009, 06:17 AM
jojomanx's Avatar
Thumbs up
That brings up another question.
"TDC to cam alignment"
Wait! (thinking)
Lets see, with a scanner and timing light it should be aligned within 10 deg.
I think thats what your saying.
The alignment was supposed to have been done by the engine shop. Looks like I will have to do this myself to get it done right!
What kind of scanner? Whats the price on them?
Old 04-01-2009, 06:23 AM
You don't need the scanner to mechanically time it.
In all honesty, if your crank & cam are aligned, & your cam & crank sensors are working properly, your ECM shuold take over & do the rest.
Those scanners are big bucks, too. You'd be better off borrowing one if you can. I'm not good with tuning, but I can tell you this: when I recently scanned my 2000 T/A, I came up with a spark advance of about 25* at idle at 178*F.
Hope that helps.
Old 04-01-2009, 03:52 PM
jojomanx's Avatar
If cam to crank alignment is off by one tooth, will the engine react as I described it in the 1st post?
Old 04-01-2009, 04:11 PM
It may. Here's me just thinking:
I don't know the actual numbers, but let's say your cam gear has 20 teeth. There's 360* in a revolution, so if you're one tooth off, you're 18* out-of-timing. (360/20=18) So even one tooth can cause HUGE problems with your timing.
Old 04-01-2009, 08:35 PM
jojomanx's Avatar
Thanks!
Old 04-01-2009, 08:43 PM
dub.ya.es.SICK's Avatar
im going with mechanical timing it may look on when timing it by putting the chain on but turn it over by hand twice it will be whackkkkkk re check the mechanical cam to crank timiing i bet that it what it is
Old 04-02-2009, 09:53 AM
jojomanx's Avatar
I just talked to Lunati and they recommended a computer scan and upgrade to match the new cam.
I know for sure that I set the timing between the cam n crank to OEM marks.
We will see!
Old 04-05-2009, 07:19 PM
BBC79Z's Avatar
Default coil pack harness
Do you have your coil pack wiring harnesses on the right side. I got mine backwards and all my car would do was sputter. Its worth a try.
The following users liked this post:
Dustin Skinner (06-01-2022)
