-8cc pistons v's -25cc pistons...
ok heres something im curious on...
im gonna forge the bottom end to aim for 800+rwhp by adding a MPT78 or a TC78...
i was going to get 317 heads + -8cc diamond pistons etc etc
but i hear u can get -25cc dish pistons, + 243 or standard 241 heads (+springs and rods )
whats the better choice? im not going to be running 20 psi or anything ( so i guess? )
but i want to hit 800+rwhp....
can someone explain the pros cons etc... or anything else i should expect etc?
sounds like either way it would be the same compression ratio but hes wondering if it would be better to have more dish in the the piston or in the head... ive heard it would be better to have the deeper dish pistons but have no expierence
Hold on fellas... Compression can affect driveability if you lower it too much. Lower compression motor makes less HP but can handle more boost.... Detonation will destroy your motor.... so you dont want that. A street driven boosted motor that you are going to run pumpgas into... (IN MY OPINION) should be below 9:1 Compression ratio... So...
To help you answe these questions you have you have to give us more info... What size motor? How do you drive it? Daily? Semi-Street? Track only? What are your HP goals? What fuel are you going to run?
daily driver / some track...
800+rwhp would be nice
241 heads with 918 comp springs + manley rods ( standard length )
( im at 500rwhp at the moment on standard bottom end + springs / rods / turbo cam / twin fuel pump set up / exaust etc )
we have 98 octane over here... ( australia )
i want something that is reliable etc... im new to the internals of ls1's.. so its learning whats " best for me "...
ok ls1 (forged 346)
Do a search for "what compression ratio" and you will find alot... read 10x buy once!
well who could i ask thats a forum sponsor about that setup etc? i dont know any of the sponsors here....
Nice setup... if your going to run 98 octane I would say shoot for a ~9:1 compression. Keeps the HP#'s up on your motor but gives you breathing room with boost. I dont know what CC Chamber heads the 241's are... but if they are ~65cc then I would say go with the -25cc dish pistons. There are alot of better folks on here to ask (alot of sponsors that build motors) then me... but this should get you started.
Bottom line on your setup.... Google a "LS1 Compression Calculator" and fill out the stats... you can play with the different CC chamber heads, Pistons, gaskets... giving you different compression ratios. If your going to run 98 Octane I say shoot for 9:1 to be safe and it will give you room to turn up the boost
i personally would like to have a bigger combustion chamber 72cc and less dish to the piston. the smaller the combustion chamber the more you motor is likely to knock. that is why diesels have flat combustion chambers.
so with your knowelge i need help.
i want to run 1000 wheel horse with only using 18psi. on 2 turbos that push 65lb/min. i have a 377 ci motor. and my compression is around 9.3:1.
will it work or no?
thanks
^^^^ you want me to call a sponser in texas about running e-85?
do they have e-85 in texas?
and sorry if i was going ot call a sponsor about boost it wouldnt be texas speed. it would be like LG motorsports. or Jim at speed inc.
