Now whats the difference....
I dont undertand. Lets just say i were getting fuel from the fuel rails instead, well thats 50-60 psi there. The solenoids dont know where the fuel is coming from. So whats the diffrence??
Certain nitrous kits are designed for high or low fuel pressure. Some EFI kits out there will just not perform well on low pressure. Now if you are talking about a direct port there can be a few reasons and differences. On smaller shot sizes you need to run a VERY small fuel jet, as a result of this its easy to clog a jet. If one nozzle gets clogged and cuts off fuel flow, it could be a very bad day for that cylinder. So to avoid this you run low pressure which will yield a much larger fuel jet. Low pressure on a DP also makes fine tuning a direct port a lot easier.
