Rear left side speaker
Old 03-30-2009, 10:01 AM
PonchoFan's Avatar
Default Rear left side speaker
Monsoon 500w system in 98 TA
Original speaker is 6.75" 2 ohm.
Found an Infinity 6.5" 2 ohm replacement.
Does anyone know the GM replacement #?
Old 03-30-2009, 05:50 PM
PonchoFan's Avatar
GM#9365799
Thanks for nothing
Old 03-31-2009, 08:14 AM
Ungrounded Moderator
WhiteBird00's Avatar
Originally Posted by PonchoFan
GM#9365799
Thanks for nothing
...Sounds like somebody has a bit of an attitude (it's really too bad that nobody looked up a part number for you in all of eight hours).
Before you start replacing speakers I suggest you read the Monsoon FAQ sticky at the top of the forum. For one thing, the sail panel speakers (next to the rear seats) aren't 2-ohm - they're dual voice coil 4-ohm subs. The signal from the Monsoon amp is low pass filtered so installing Infinity 2-ohm full-range speakers there is definitely not a good idea.
