Pulling lt1 with m6 or without
Pullin the lt1 from 94 camaro,is it easier to pull m6 with the motor or to unbolt trans . Motor is coming out top. How hard is it to align input shaft and motor when going back in? THANKS JB
After pulling my motor from top, I will recommend to just drop everything at once out bottom if you can. There is way less unbolting everything in cramped space.
It is not too hard to put back in. You cant be a weakling if your doing it by yourself. (unless you have trans jack)
I've done it so many times (on my car and friends) I am just going to pull it from the top with no tranny. If I change a pan or gasket I'll drop the k member a little bit and change that out with the k member hanging on the last few threads of the bolts
No brake bleeding involved.
Able to roll the car out after pulling motor.
No shifting the cradle
Is just a few reasons off the top of my head...
Brake bleeding doesn't take long, easy to do with a mighty vac.
You can roll out the engine & tranny, similar to rolling the car away.
I have done both methods several times, I'll never pull the engine out the top again if I don't have to.
What does shifting the cradle mean?
Yeah but what happens when you remove the engine and transmission and you need to roll the car out of the garage. Let me guess remove engine and trans and put cradle back into car. So you can move car.
For the person with no lift and a lift that they can not leave their car on indefinitely. thru the top is easier and less work.
I have done it all kinds of ways. and I am not saying there is a correct way. But if you actually have to use the area you are working in when done or you dont like the additonal work. Then pulling it thru the top is the smartest way
Um or not bleeding the brakes at all
I took my engine out the top in 2-3 hours. Pulling it with the transmission is much faster but you'll have to remove the hood. I was also using impact gun makes it go lot faster.
Out the Top
remove hood
drain engine oil
drain trans oil
drain coolant
raise front of the car
remove coolant hoses
remove radiator / fans
remove crank pully
undo power steering line
undo fuel line
disconnect battery
remove engine harness
remove drive shaft
unbolt engine mount
unbolt exhaust / Y-pipe
remove torque arm
unbolt shifter
unbolt trans crossmember
pull engine out
Out the Bottom
disconnect battery
drain coolant
Raise front of car
support subframe
remove front wheels
remove shocktower bolts
undo fuel line
disconnect brake line
remove drive shaft
remove torque arm
unbolt shifter
unbolt exhaust
lower engine/subframe
pull engine off subframe
Out the Top
remove hood
drain engine oil
drain trans oil
drain coolant
remove crank pully
undo fuel line
disconnect battery
remove drive shaft
unbolt engine mount
remove torque arm
unbolt shifter
pull engine out
Out the Bottom
disconnect battery
drain coolant
Raise front of car
support subframe
remove front wheels
undo fuel line
remove drive shaft
remove torque arm
unbolt shifter
unbolt exhaust
I have helped pull from the top on a friends car, it sucked compared to going out the bottom. The picture of the car is just showing that i put the k member back under the car. I pulled the motor and trans, seperated the motor from trans, put in on the stand, and put the k member back under the car in one day taking my time. It was my first time pulling an engine out by myself and it was spuper easy and a load of fun, and i dident break anything!! lol And bleeding the breaks isnt hard, i dont know y it would even be an issue.
Yup I have worked at chevy dealer for about 10 years, ive removed a lot both ways, worked in heavy line and tran's department. Ive always done it out the top on the LT1's because had to roll the car out of my rack/lift to pull in other cars.
If its a LS engine corvette I would say out the bottom only! lol
