Cadillac CTS-V - tire and lowering questions
original786
03-30-2009, 03:54 PM
so im thinking if i should lower my 2005 cts v
option A: lower with either eibach or h&r springs on stock wheels
* any one perfer one over the other, i dont want a huge drop just a little
option B: should i get all wider tires all around (265-40-18)
* is that a good size to go with or should i change it up, i dont want any rubs becasue i will be putting on either the eibach springs or h&r springs.
option c: should i go with stagg look. 245-40-18 front, and 275-45-18 in rear
* does that sound the right stagg tires to go on stock wheels.
* or does any on suggest differnt stagg sizes and will i need any modification.
* will it mess my handling up going with stagg beside all the same tire size all around..
thank you
whisler151
03-30-2009, 05:59 PM
thank you
Im lowered with Eibach and running 245/40 and 275/35 on stock wheels. I love the setup.
CTSV_510
03-30-2009, 06:30 PM
I am running 265/40 all around and I highly doubt you could run these tires in the front if you were lowered.
original786
03-30-2009, 06:33 PM
you have picture of your car whisler with the lower setup?
whisler151
03-30-2009, 07:34 PM
http://www.ls1tech.com/forums/picture.php?albumid=9141&pictureid=20588
http://www.ls1tech.com/forums/picture.php?albumid=9141&pictureid=20587
HartmanV
03-30-2009, 07:38 PM
Whisler, no vibration issues running a staggered setup on the same width wheels? Just curious how the car feels.
original786
03-30-2009, 08:43 PM
yeah any issues..
having the bigger gap in the rear is that normal
i heard you can get some type of bushing from nel (i think thats his name)
that lowers the rear a little more..is that true?
original786
03-31-2009, 11:15 AM
bump!
Brentman2007
03-31-2009, 12:54 PM
id go 245 in front and 265 in back if i were you.
and if you have an 04 the fenders came rolled from the factory so you could probably go 275 in back
Here is mine with 245's all around goodyear eagle rs-a's and H@R springs (they came on the car and they run wide from what im told they are more like 255's) To give u an idea of drop and tire size
http://www.ls1tech.com/forums/picture.php?albumid=695&pictureid=19815
http://www.ls1tech.com/forums/picture.php?albumid=695&pictureid=19818
http://www.ls1tech.com/forums/picture.php?albumid=695&pictureid=19819
original786
03-31-2009, 03:15 PM
are you on stagg tires now??
or still stock
Brentman2007
03-31-2009, 03:33 PM
or still stock
Still stock. 245 all around. I just cant bring myself to spend the money on all new tires just yet but im pretty sure 265 would fit out back easily :D
original786
03-31-2009, 03:57 PM
245-??-18?
MIGHTYMOUSE
03-31-2009, 04:11 PM
are those bfg kdw 2's on the back? trying to copy..
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
