Best way to clean O2 sensors
Old 03-31-2009, 11:20 AM
foreverzero's Avatar
Default Best way to clean O2 sensors
I just took my 02's out to look at them and they have a little carbon on them, what is the best thing to clean them with? Im just worried if i use brake cleaner it might mess with the sensor reading the wrong stuff when I put them back in
Old 03-31-2009, 07:13 PM
TheSilverOne's Avatar
burn the carbon off
Old 03-31-2009, 10:02 PM
I try that one, everyday!
Old 03-31-2009, 11:50 PM
tripps's Avatar
Not sure why you want to clean them.. you don't need to clean o2 sensors, only replace when they go bad. Brake cleaner is horrible for o2 sensors.
Old 04-01-2009, 11:47 AM
Notmyvette's Avatar
Cleaning the carbon off won't do anything at all, I used to do it cuz it seems right but in reality it doesn't, the outside is just a casing with holes or slits in it, the exhaust goes through the passages and the amount of oxygen is read.....as long as the holes, slits or whatever it has is open and not clogged then that's all you can really do.
Old 04-01-2009, 11:51 AM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I have read many articles on this..ALL of them say..DO NOT CLEAN. Everything leaves a residue which is bad.
Old 04-02-2009, 11:10 AM
Thanks guys, not cleaning the 13111's!
Old 04-02-2009, 02:29 PM
7plagues's Avatar
edited so no one gets antsy to try.
Old 04-02-2009, 03:52 PM
Frost's Avatar
Originally Posted by 7plagues
I've heard of taking them off heating them up with a torch and dunking them into water which will allow the excess carbon to "flake" off. Makes sense in theory, but who knows if it actually matters with the sensor
NO!!! You can heat them up with a torch; I've revived a few widebands like that from fat-running cars but do NOT dunk a hot sensor in water. The sensor element is glass (glass like) and could easily crack like that.
Old 05-24-2009, 03:17 PM
JasonWW's Avatar
How can you check to see if the glass is cracked?
The reason I ask is because I had some water sucked through the engine and now it idles at 1500-2000. My rears are deleted and the code is removed. I'd really like to check them some way because I don't have any money to waste.
Thanks.
Old 05-24-2009, 07:30 PM
PowerShift408's Avatar
Here's the best way to clean them by far: Buy new ones.
Old 05-24-2009, 09:41 PM
35th SS's Avatar
I just burned them off with a handheld propane torch or just buy new ones for like $175 a pair from napa bosch 13111.
Old 05-24-2009, 10:36 PM
Originally Posted by 35th SS
I just burned them off with a handheld propane torch or just buy new ones for like $120 a pair from napa bosch 13111.
Fixed it for you.
Old 05-24-2009, 10:43 PM
LS6427's Avatar
Densos....$120.00 for 2 sensors is what I paid recently at Bennett Auto.
Old 05-25-2009, 08:09 PM
35th SS's Avatar
Originally Posted by PowerShift408
Fixed it for you.
$175 here on the island.didnt buy em yet.just clean em for now.
Old 05-04-2017, 06:18 PM
J Hawkins's Avatar
OUCH! $175
There is a reason I'm driving a 1989 Vehicle!
Lol
Old 05-04-2017, 07:56 PM
Received 3,021 Likes on 2,352 Posts
Originally Posted by J Hawkins
OUCH! $175
Lol
And that was EIGHT years ago!
Quick Reply: Best way to clean O2 sensors
