LS7 engine and manifold... what TB?
Old 03-31-2009, 04:09 PM
brianfromhawaii's Avatar
Default LS7 engine and manifold... what TB?
I am putting a LS7 in my camaro, i have the manifold and the engine, but i dont know what throttle body i can use... ideas?
Old 03-31-2009, 04:13 PM
Stang's Bane's Avatar
Any 90mm cable TB will work..
Old 03-31-2009, 04:20 PM
What ones will bolt up to the LS7 manifold? Will a FAST bolt up?
Old 03-31-2009, 06:25 PM
sandragnx's Avatar
Any 90mm tb will work but you will also need a TB spacer.With out the spacer,the thottle cable cam hits the manifold and does not allow full trottle.ETP sells them for like a hundred bucks.I just did one with a ptm92 mm tb to a ls7 intake.Works real good and also has holes to mount your cable bracket.
Old 04-01-2009, 03:53 PM
My Holley worked fine. No issues whatsoever with clearance...
Old 04-01-2009, 06:53 PM
king2000z28t56's Avatar
sell the ls7 manifold buy a single plane from gm throw an elbow on it then you can step it up to a 100+ mm throttle body
Old 04-01-2009, 09:42 PM
sroach20's Avatar
my nick williams tb is a work of art.
Old 04-01-2009, 11:02 PM
no thanks.... ls7 manifold was modded by nitrous outlet... 250 shot direct port!
Quick Reply: LS7 engine and manifold... what TB?
