4in''stroke and 30 over Piston = what cubic inch?
There is a formula to figure out cid...dose any one know it... i think its like bore x stroke divided by 8 = cid..... also if i have a 4inch stroke and a 30 over pison what cid is it,if its a ls1 block? thanks
a 408 is a 6.0 block with a 30 over and a 4 inch stroke. You cant go that much over on a stock ls1 without sleeves in the block.
the formula to figure it out is the total displacement of the engine, so you take the area of a circle(pi x radius^2) times the stroke of the engine times number of cylinder.
Ok so who has a 383 out of a 5.3?
I pulled a 5.3 out of a customers truck and I'm going to build a 383 I just want to know who has used a 5.3 block and if your hitting it with nitrous, how big of a shot are you using?
1 Post
Unless I messed it up then an ls1 30 over (3.898 + .030 = 3.928) with a 4 inch stroke is 388
