Clean YOUR FAST intakes!!!
well as i was replacing my cam and oil sensor, i decided to take the FAST apart and make sure everything was ok. ive had it on now for just about 2 years...
i take it apart and holly hell!! i didnt realize how dirty it was, it was drenched in oil and dried oil.
so i proceeded to clean the top and bottom out w/ a brillow pad. afterwards, i headed down to Race Proven Motorsports to have them port it while its off...
so moral of story, i recommend cleaning it once a year, if you have a catch can, id still go in to double check....
next on the list when i put my TFS's on will be a catch can.
i think it could have been robbing me a few ponies, but who knows. when it goes on i should be picking up some lost ponies plus a few extra w/ the port job
-brandon
ps i didnt get any pics, but i was thinking about it while cleaning lol
-brandon
We recently had a problem when the GFs car developed a missfire/hesitation.
It turned out to be a combination of fouled plugs and leaky intake gaskets.
Heres what #7 and #8 plugs looked like, the rest looked great, and all were about 1 year old NKG TR55s.
We replaced the intake gaskets, heres what the ports looked like.
We cleaned the inside and outside of the LS6 intake at my works parts washer, squeaky clean!
I came to the conclusion that the cause of this was, 1: it didnt have a catch can, but we installed one recently.
And 2: The car ran great for several months after we did a cam, LTs, new plugs, etc. Then we moved to new apartment complex where the parking lot is at a steep angle. I figured that was causing the oil in the intake to collect at the rear of the manifold at get sucked into #7 and #8. The car only developed the missfire/hesitation a couple months after we moved here.
So Ill be keeping a close eye on the catch can and rear plugs in the coming weeks.
Oh its not that bad once you get the hang of it. #7 just takes a couple minutes to remove. To get #8 just remove the coil pack and its cinch after that. 15-20 minute job tops to get them out and back in.
I can actually do all 8 plugs on the other car (LT1) in 45 mins.
Yep, I`ve tried everything and the only way to keep oil and hot oil vapor out of the intake is to cap off everything and go with a breather. The car now runs much better and no more fouled TR6s!
