383 with the GM 847
383 with the GM 847
Any one here running a 383 with the GM 847 cam? Would like to know if they like this combination. Also if they ran into any problems with the rods hitting the cam. Thanks
ive learned with a 383 anything over 550 lift rod clearance is an issue. or lobe lift of .390
been there and done that.
the one on the top is a comp cam. then i went to a lunati with a 4/7 swap and a small base.
that was the second comp cam i had. the first one the lobes started to flake off it. then i bought the same one to replace it. and it ran for a year then snapped.
