Mufflers right after the header
Old 04-01-2009, 07:52 AM
WS.666's Avatar
Default Mufflers right after the header
Is there any disadvantage to running the mufflers right after the headers (bullet mufflers) and then running the pipes to dump before the axles?
Old 04-01-2009, 07:55 AM
teke184's Avatar
ground clearance
not much room behind the drivers side header collector.
Old 04-01-2009, 08:13 AM
plaf713's Avatar
fuggin loud
Old 04-01-2009, 10:39 AM
TXZ28LS1's Avatar
id like to know also. ive been tossing around the same idea. i was thinking of borla XR1 muffler right off my pacesetters.. has anybody tried it? any performance gains by doing that instead of going with an off road y into a catback?
Old 04-01-2009, 10:47 AM
Notmyvette's Avatar
I've always heard it's best to put the mufflers as far back in the exhaust system as possible..which is where all the car manufacturers put them so I guess it's true..prob meaning chambered mufflers though...
Old 04-01-2009, 03:00 PM
teke184's Avatar
depending on the power output of the car....a ypipe and catback is more restrictive.
especially when you consider all the exhuast is going through ONE muffler as compared to TWO on a true duals setup.
for dealing with noise, interior resonance, and ground clearance...do an X or H pipe and then the mufflers.
Old 04-01-2009, 07:12 PM
98RedBird's Avatar
lol good luck with that. I thought the same thing until I purchased and received the XR-1... the thing is HUGE. No way it will fit behind the collector on the drivers side. The passenger side however, it will fit behind.
Old 04-01-2009, 11:11 PM
kustomtool's Avatar
Default further back the better
The exhaust gasses cool as they go back so there is more power to be had as there is less restriction till later. Whether it is a very measureable amount I couldn't say. Plus , as the others said, better ground clearance & placement.
Old 04-02-2009, 10:00 AM
TXZ28LS1's Avatar
lol..thanks man. thats what hear the biggest problem is..clearance.
Quick Reply: Mufflers right after the header
