off the wall LT1 ???
Old 04-01-2009, 08:12 AM
imperial07's Avatar
Default off the wall LT1 ???
has anyone tried carbing and running there LT1 on methanol? just a thought a circle track guy put in my head a while back about trying to make more power with my LT1. the engine isn't in a car right now and its a project that may turn into a drag only motor.
Old 04-01-2009, 11:20 AM
ss.slp.ls1's Avatar
What kind of power are you trying to make that would make you consider such a set up?
Old 04-01-2009, 12:04 PM
Ken95Z28's Avatar
Yes, I just got done doing this over this past winter.
If you have time look at my write up about this project.
http://www.teamandersonracing.com/ProjectMethanol.htm
So far I'm happy with it.
Old 04-01-2009, 12:40 PM
imperial07's Avatar
power isn't the issue, i can make power by just using boost or N2O, its more or less of how the power is made. if i would do this it would stay N/A thats why i'm asking. the motor when put together should make somewhere around 600 at the flywheel on pump gas, but that is with a SR street cam. with a dedicated drag cam i would like to see 700 flywheel in N/A form. its already max c.i.d. with 410.
Old 04-01-2009, 12:42 PM
imperial07's Avatar
dude that is awesome, what kind of power do you make? i was going to carb it and stick it in a 2800lbs. car with strong but light as possible drivetrain.
Old 04-01-2009, 06:40 PM
Ken95Z28's Avatar
I really don't know what the Dyno numbers are on this setup. The Gas setup with the same motor, heads and cam made right at 400 to the wheels.
This I do know that I picked up almost .3 in the 1/4 and almost 3 Mph.
I picked up more torque then anything else, the 60's went from low 1.6's to an average 1.55. Once I put a different rear gear in this it should pick up some more.
Old 04-01-2009, 08:42 PM
gregrob's Avatar
Methanol is awesome!!! I dont run it in the car but I run it in my bikes and love it.
Crank up the compression on your build and don't look back.
I wouldn't run it on a street car, but a track only, it's the only way to go. Runs cool, super hard to detonate, makes more power. Neat stuff
Old 04-02-2009, 12:17 PM
imperial07's Avatar
i can't crank up the compression to high since i'm already .040 overbore, i might get lucky with 12.5:1 and hope it stays together.
Quick Reply: off the wall LT1 ???
