How big of a rear tire/rim would you guys run?
Old 04-01-2009, 01:54 PM
blkZ28mara's Avatar
Default How big of a rear tire/rim would you guys run?
My car is in my sig and i plan on getting LPP headers and a stall sometime soon. I also plan on getting some chrome zr1's to replace the salad shooters. Should i just get the 9.5s? Or would i be better off with the 11 inch wheel and run 315s? Do you have to modify the wheel well at all with the 315s?
Old 04-01-2009, 02:30 PM
udienow's Avatar
Well generally wider is better, but it all depends on tire types and stuff... you could grip just fine with a 275 wide DR. However wider looks cooler IMO, so for that reason alone I would go with the 315's, its what I did.
As far as fitment, it depends on a few things. Is your car lowered? Camaros I do believe have a smaller wheel well, so you will likely have to at least take a BFH to the inner fender wall, or roll the fenders. On stock height u might get away with doing nothing.
hitmanws6's Avatar
if you plan on racing it at all get the 17x11. but if its a DD a 17x9.5 is plenty big
Old 04-01-2009, 02:38 PM
blkZ28mara's Avatar
I will be putting 555Rs on the back. It is my summer car and i take it to the track 4-5 times per summer. My only concern about going with the 315s is the 10 bolt.
Old 04-01-2009, 02:40 PM
blkZ28mara's Avatar
And i really never plan on lowering it, at most i will probably do the heater hose mod in the back.
Old 04-01-2009, 02:43 PM
streetassasin's Avatar
I have a 17x9.5 rim, MT 275/40/17 DR's, and they almost dead hook on the street with no burnout launching on spray
Old 04-01-2009, 02:57 PM
TXZ28LS1's Avatar
thats a tough one.. yeah have big fat tires looks sick when your looking at it from the rear with the tire sticking out.. but when u like at an angle its pretty ugly seeing a fat tire stick out.. i prefer to have the tires that just fill in the fenderwell.
Old 04-01-2009, 03:29 PM
HWI
HWI's Avatar
I'm running 18x10.5's wrapped in 295 Goodyear Eagle F1 GS D3's, no complaints here, though it seems most people run a 305 on 10.5's, the 295's work good for me.
Old 04-01-2009, 03:36 PM
dman3's Avatar
I plan on putting a 305 tire on a 10.5 rear wheels.
Old 04-01-2009, 03:51 PM
BOLO's Avatar
You can't beat the look of chrome ZR1's on a camaro, especially 17x11 with 315/35's in the rear. Another wheel option would be TT2's,IMO.
Old 04-01-2009, 05:08 PM
blkZ28mara's Avatar
Yeah i love the chrome zr1s. Any of you guys run 275s in the front? Is that too wide or will that be okay too
Old 04-01-2009, 06:09 PM
bigj2717's Avatar
275 fit fine up front. Might rub alittle if ou try to trun the wheel too sharp but normally theres not issue
