370 dyno
370 dyno
just got back from epp results are in
heres the setup
tsp 370 11.6 comp full arp hardware
prc 2.5 ls6 milled to 60cc 40mil gaskets
ms4 on a 112+1
long tubes with rumbler catback with a cutout
bbk intake and throttle body slp mass air
kn firepack
dual walbros intank with speed rails and a rail mounted reg -8 feed line -6 return 42 p inj
150 wet shot
going through a 6 speed 12 bolt with 4.11 and a 28 inch drag radial
motor was
470 rwh & 440rwt
on the bottle was
600rwh & 640rwt
i dont have a scanner so i cant put the graphs up and i need a fast intake the bbk was running outa breath at 6300 but im still happy
heres the setup
ms4 on a 112+1
kn firepack
150 wet shot
motor was
470 rwh & 440rwt
on the bottle was
600rwh & 640rwt
1 Post
Sounds like she is pretty nasty on the spray brother !! The fast should help out some. Good luck !!
Vengeance racing is having a sale on their ported FAST 92's. They also open the inlet to 96mm so it can accomodate the new Nick Williams 96mm tb. Should be a big help to you and your new motor. Ditch the BBK asap. Tell Ron that Doug sent ya.
those are great numbers, i wonder if it will be enough to hold off the cobra with both of you off the bottle and on have you taken any weight out?
lets hope the weather is good saturday i cant wait to see your car in person
QUOTE=kevin99hoss;11356336]those are great numbers, i wonder if it will be enough to hold off the cobra with both of you off the bottle and on have you taken any weight out?
lets hope the weather is good saturday i cant wait to see your car in person [/QUOTE]
thanks about that cobra only one way to find out and i cant wait i have never got to run a cobra ya iv removed some **** i weighed to yesterday before dyno it was still kinda heavy at 3495 with half a tank of gas i thought it would be lighter but i have also added a iron block, 12 bolt, rollbar, heavy duty susp peices i think the weather is still going to be nice whish it was alittle bit warmer
thats cool it can be never ending sometimes
thanks hopfully soon
