help me lower my 60'
as of right now the z has cut a best 60' of 1.61' but on average its around a 1.65
Its a bolton only car with a ss3600 and 3.73.suspension mods as of right now consist of
qa1 r series in front(shocks)
qa1 single adj in rear(shocks)
eibach prokit springs in rear
no front swaybar
bmr adj lca
umi relocation brackets mounted on third hole
255/5016/mt dr on 22psi
I get the best 60' flashing the converter or stall to about 1,000 to take alittle shock out of the rearend.stock 10 bolt with 3.73
I usually set the fronts at 2 and the rears at 6.the car feels like it does not spin,just hooks and goes straight down the track.I am not going to change the tires right now I want to keep the snowflakes on to look like a real street car.what can I adjust or buy to help get the 60' down to about a 1.55'
no front swaybar
bmr adj lca
Location: Currently, Zormat, Afghanistan....Home staion, FT. Richardson, Alaska
raceweight is around 3,280.as far as squatting im not sure I usally go by myself or my gf goes I would have a video but most of the time the races are at night. hah time in sig was old setup,ive made quite a few changes,removed n2o,deleted the AIR,installed ft85mm airlid,zo6maf,tune,relocation brackets.
debating on torque arm or rearswaybar.
no front swaybar
bmr adj lca
no front swaybar
bmr adj lca
