ZO6 valve springs
Old 10-23-2003, 09:10 AM
gee65's Avatar
Default ZO6 valve springs
I'm installing a 2002 ZO6 cam in my 2001 TransAm 6sp. trans.I plan on sifting at 6300 rpm, do I need the ZO6 springs? I have 23,000 miles on the car.
Old 10-23-2003, 09:20 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Default Re: ZO6 valve springs
Yes.
Old 10-23-2003, 09:31 AM
cyphur's Avatar
They're rated specifically for that cam....I'd swap for them if it were my car. Better to spend a few extra $$ then risk messin up your motor.
Old 10-23-2003, 12:34 PM
jimmy 2 Times's Avatar
did the same thing in my 01, you def need the springs
jimmy
Old 10-23-2003, 08:18 PM
Greg_E's Avatar
I would definitely go with the ls6 springs. The higher lift cam is only part of the equation. The 2002 LS6 also uses lighter weight valves. Bigger cam + heavier valves + 6300 RPM = trouble IMO.
