Defective HSW Bottle Pressure gauge?
Man.. I've had nothing but problems from this kit. First the fuel noid was bad.... now the bottle pressure gague is defective?
Please tell me I am wrong on this...
I just had the bottle filled the other day and this being my first kit didn't know what kind of pressure to be looking for. My bottle pressure is only 300psi... and I am afraid to hit it with the bottle heater because I think 300psi is WAY to low... even for a cold bottle.
The gauge is mounted on the bottle.
Any input?
Any input?
Any input?
Any input?
Put the bottle in some hot water for a minute or so and see if the pressure starts to rise.
Again, we hate to see you having problems with your kit, its always a risk when buying used. did you contact the seller to get anything back? If he didnt make you aware of any problems i think you would be due a refund.
Update:
I just sat the bottle in some bath water... the temperature was warm... about the average I would use for a bath. The bottle pressure was rising... and after 10-15 seconds it was over the 400 mark.
Is there anyway I can confirm this gauge is bad? I've got a dyno tune scheduled for saturday and would hate to reschedule because the gauge doesn't work.
Update again.
I left it in the tub for about five minutes, and the pressure rose to around 700 PSI.
700 PSI should be what the bottle reads with no heat in it, cold.
how often do the gauges go bad? What actually could be wrong.... anyone?
its not so much that the gauge goes bad, usually they are damaged. If it wasnt packaged correctly during shipment to you it could have gotten banged and the needle gets stuck. It doesn't seem like this is your problem, more so for the one thats stuck at 100psi. Nick said you guys had been pm-ing so hopefully you can figure something out
What could cause the gauge to read low? The needle moves.... the bottle does not leak. Could a bad nitrous fill... or anything along those lines cause this problem? I haven't PM'ed anyone except about jet sizes... I am just worried that if I crank the bottle up to the 1000psi or so it needs to be.. it would actually be 1500 or more....
As far as my guage being off 100 lbs., I could care less. I call it normal wear and tear because it's been under pressure for 2 years.
Buy a new guage with a fitting and put it between the feed line and bottle to check your current gauge. If you current guage is bad, you now can replace it with the new guage or just leave the new guage between the line and bottle and not worry about the bad guage.
And a gauge with a feed line and bottle would only read once I opened the bottle, correct?
i dont see how this is anyones fault but your own. why would you buy a used kit that was not taken care of? why didnt you check all this stuff to make sure it worked before the purchase? why try to make hsw out to be **** when your the fool that made the bad purchase. you bought used deal with the consequences and quit crying. all this cause you saved 100 bucks.
Because its harrisspeedworks parts.
The user I bought it from is a member here, he has 100% feedback. ScreaminBird99.
He pm'ed me today and swears the kit was in 100% working order when he packed it up and shipped it out.
I am not the only one that has had problems with HSW noids.... the purge one seems to be the big culprit of problems.
This is the first I've seen of a bottle pressure gauge going bad. I mean unless you just make it with the crappiest quality parts ever how does it go bad? If it was damaged in shipping it would either be a stuck needle, or not work all together. It just appears to read about 450 PSI low which is enough to get someone killed that didn't know better and heated the bottle too much.
