View Poll Results: Which cam should I order?
Futral Motorsports F14 232"/234" .598"/.598" 112LSA
29
53.70%
Texas Speed Torquer V.2 232/234, .595"/.598" 112LSA
25
46.30%
Voters: 54. You may not vote on this poll
FM14 vs. Torquer V.2
Which one should I get?
I've been researching for awhile and think I've narrowed it down between these 2.
Feel free do discuss their differences...
Wasn't my intent. But, you have to admit.......? I had a Comp Cams XER281 which has the same specs as the TII. I bet it would be hard to tell the difference between any of the three...if there is any. Comp probably grinds all three and just stabs them into different boxes.
I had the F14 and it is a great cam. There is really good torque numbers that come off the Futral cams. The area under the curve is great, and driveability is no problem when tuned correctly. I was making 423 rwhp 408 rwtq in my Z06 with just the cam and bolt ons. I changed the Ls6 heads for Dart 205s and went up to 451 rwhp 423 rwtq.
my vote goes to the f14
Do you want hp #'s or a track time? I have a futral cam in my car with Trick Flow 215cnc heads, stock bottom end motor and 3600lbs with me in it.. Check all motor N/A run in my sig..
I vote for whatever cam he^ has
bet you would never be able to tell the difference if installed in the same motor.
MAYBE on an engine dyno where all conditions are repeated. but even then it would be splitting hairs.
