Cam suggestions - A4 Only (No Stall) Daily Driver
Would like to get the best cam for the $$$ and make the most power while still being able to daily drive it. (A4 with a stock stall converter w/ 3.73's) It has a shift kit but I'm pretty sure that doesn't matter in this case.
I got mustangs to beat, Yes I have searched.
Ran a stock stall and a 224 cam...picked up 8 tenths and 7mph. That's more than the average person gets with a small-medium stall and stock cam.
I added a 3500 later on and picked up another 5 tenths.
It drove the same before and after the stall.
Hope that helps
Hope that helps
best bang for buck with stock parts...id say look around in the classifieds for an 02 -04 ls6 cam and springs...i picked one up for my 5.3 for 160 shipped.....in an ls1 its normaly a 20+rwhp gain.....and you will be fine on the stock exhaust....however I like everyone else am gonna suggest doing all your bolt ons 1st it will net you more in the long haul......
good luck....
good luck....
LS1Tech Premium Sponsor
We ran a TSP 220R camshaft in my wife's stock stall 35th with great results. It gained approx. 35rwhp & still drove pretty well with a near stock idle rpm & stock verter. Give me a call if we can help you with your purchase, we stock those things for just this application!!
http://www.texas-speed.com/shop/item...d=174&catid=49
http://www.texas-speed.com/shop/item...d=175&catid=49
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Sorry, I should have mentioned this in the original post.
Ya, it has a lid.
Shortly it will have longtubes + 3" Y and LS6 Intake
After all that, Then the cam would be my final mod for a while (besides for dyno tune)
So stall's don't effect driveability dubrado? (And anyone else)
I assume it would effect MPG's a ton right?
Ya, it has a lid.
stalls should do next to nothing as far as mpg's go. it will be a lock up converter and will drive the same as your stock one at highway speeds. go with a nice 3600 stall speed. .02 as mikeg said, that would open up your choice for a cam if you want good power. you could go quite a bit bigger.
What would go good together?
I can just throw a stall in and not have to worry about the trans itself?
It shifts excellent at WFO. (After **** *** hypertech was removed)
if your worried about the trans, then dont get a cam IMO. MOST cams require RPM, which seems to be the biggest killer of a stock trans. a stall doesnt really hurt a trans, but you will need a trans cooler. with a stall, you could have your pick of a lot of the bigger cams out there. pick your poison.
I know most think this is a Baby Cam but the Comp Cam 212/218....525/530...114 lsa
will run on the stock tune and provides excellent Low-Mid range power and torque.
It drives good and you save $300-$500 on a tune. My 216/220 cam effected my MPG. A higher stall will effect your City driving but not the HWY too much. The cam will effect your MPG more than a converter. For a daily driver, I wish I had gotten the 212/218.
Everyone always has a different oppinion when it comes to this. My buddies 2001 formula has a Futral F14 high lift cam in it with trick flow 215cnc heads and he is still running the stock stall converter.. It does tend to want to stall at idle but the car is a monster on the street. His car leaves so damn hard on the street due to the stock stall I play hell trying to stay on side of him.. Now at the track it's a totaly different story!!
