TR224 with a 7.350" Pushrod?
Old 10-23-2003, 12:47 PM
H&H Performance Depot's Avatar
Default TR224 with a 7.350" Pushrod?
I need some more power so I thinking about running the TR224 cam with 114 LSA with the stock heads. And just buying some Comp Cams 26918 Valve Springs and using stock retainers and such, money is sorta tight now cause my mom is stupid but that is a diffrent story. So my question is I already have some brand new Comp Cams 7.350 pushrods sitting here so can I just use those for the TR224 or can do I need to use a 7.400 pushrod?
Old 10-23-2003, 12:50 PM
1fastWS6's Avatar
Default Re: TR224 with a 7.350
That'll be too short. You want the 7.400 for stock heads. BTW, that's the cam I have and it's awesome!
Old 10-23-2003, 01:00 PM
Default Re: TR224 with a 7.350" Pushrod?
ok, will the stock pushrods work or? And can I use the stock retainers with the comp springs?
Old 10-23-2003, 01:16 PM
Tally TransAm's Avatar
stock retainers yes, stock pushrods i wouldnt
Old 10-23-2003, 01:57 PM
quickWS6's Avatar
Just for reference, when should someone use a 7.35" pushrod? I can only see it as when someone has milled heads and stock cam, someone has milled heads and same base circle as stock cam, or someone has an aftermarket cam and some seriously milled heads. Or, if someone needs very little preload, they would need shorter pushrods, also correct?
Old 10-23-2003, 02:56 PM
Retsik's Avatar
To add to what quickWS6 asked, does the TR224 have a smaller base circle than the stock cam - and if so, does it require a larger pushrod?
I bought mine as a kit from TR, and have the stock 7.40" rods, but want to double-check...
Old 10-23-2003, 03:43 PM
quickWS6's Avatar
Yes, the TR224 has a .030" smaller base circle then stock. The TR pushrods are .015" longer then stock, and if using stock lifters, it should not be a proclems. Even stock pushrods should be fine with stock lifters.
Old 10-23-2003, 05:21 PM
Sooo would I be ok if I run stock lifters, stock retainers, stock pushrods, and comp springs, with the TR224
Old 10-23-2003, 05:24 PM
jmX
jmX's Avatar
Yes, you will probably be ok. What does your mom have to do with any of this anyway?
Old 10-23-2003, 05:30 PM
Divorce
Old 10-23-2003, 05:43 PM
1ScrudeDude's Avatar
Wow, glad to read that, my 224 goes in tomorrow night!
For all that may be interested, my head/cam combo only costed me $1899.00 (stage 2) at Speed Inc.
See sig...
Old 10-23-2003, 07:48 PM
Brian2001SS's Avatar
The stock pushrods may not be a good idea. You will want to run stronger ones with that cam or you will bend them right and left.
Old 10-23-2003, 08:29 PM
02RED Z's Avatar
I think 7.35 pushrods will be fine . I ran them with a C-2 cam for over a year without any problems .
