Pontiac GTO 2004-2006 - windage tray part #?
SilV8
04-02-2009, 10:50 AM
Does anyone know the GM Part # for the GTO windage tray?
mrtosh
04-03-2009, 02:51 AM
Windage tray?? May want to elaborate a lil on that one.
SilV8
04-03-2009, 07:18 AM
Im doing an LSX swap into my 240sx and I have to use a GTO Oil pan, pick up, and windage tray. Im guessing the windage tray is the baffle or w/e that goes in the pan.
I have part numbers for everything else I need I just cant seem to find a windage tray part #. Even in the oil pan thread on here there are "????" in the windage tray slot for the GTO oil pan
bsman
04-04-2009, 08:25 PM
I am getting ready to put in an order myself, here are the part numbers I found... You should probably double check them with your local GM parts dealer though...
Oil Pan (pan, non magnetic plug, gasket and bolts) GM# 12581209
Oil Pan Gasket GM# 12558760
Magnetic Oil Pan plug GM# 23011420
GTO (Holden) Oil Pump Pickup GM# 12572654
GTO (Holden) Windage Tray GM# 12558189
GTO (Holden) Dipstick GM# 12562468
GTO (Holden) Dipstick Tube GM# 12561544
SilV8
04-04-2009, 11:58 PM
Thank you very much! I am going to save these part numbers to my comp! :rock:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
