how much power???
Old 04-02-2009, 02:54 PM
caviness's Avatar
Default how much power???
how much power or tourque will a built stg 3,4,or 5, 4l60 and 4l80 hold up to,did search could not find anything,want to change latter and need sum info,car will be a street and track car about 50/50 stall will be in the 3600 to 4200 range dont know exatlly whitch one yet,but need sum ideas.
Old 04-03-2009, 04:53 PM
caviness's Avatar
how about sum good guesses,and will be spraying latter when i can afford a kit,if no guess if you got a4 and 500 or more hp tell me what your running and how its holding up..
Old 04-03-2009, 05:10 PM
LS1Tech Sponsor
performabuilt's Avatar
How much HP something will handle is always just a guessing game there are just to many variables , Rear ratio, weight of car,stall, tire type and sized, wether its sprayed and how. HP numbers like we have on our site are just general guide lines and are actually decided on a case by case basis at actual time of order. Then of course knowing who did the trans and when and how many miles is again a variable.
I will say we have quite a few guys running alot more HP than you show in your sig in the levels 1-2-3. In many varying applications as do the other vendors here. But calling something a level 1-2-3-4-5 is meaningless without knowing who built it.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-04-2009, 10:27 AM
caviness's Avatar
thanks for the reply and it will be built buy one of the sponsors,ill decide who latter just wanted to get a little heads up on sum information,and witch trans ill go with so ill have sumthing to think about when my t56 goes out.
Old 04-04-2009, 10:38 AM
FLT
FLT's Avatar
Feel free to give us a call when the time comes. I think you should be looking at one of our level 4 builds for what you currently have. With the NOS, depending on how much, a level 5 would be a wise choice. We do offer billet input and output shafts if you want to build the strongest we offer. Give us a call. Vince
