parts i need
parts i need
ms4 cam.
prc 215cc heads.
fast 90/90 intake
texas speed 100mm mass airflow
12 bolt moser with 3:73's, hd posi diff, doesnt matter about traction control.
42lb injectors
walbro fuel pump for this steup
suspension:
aftermarket k member
aftermarket a arms
subframe connectors(weld in)
strut tower bar
panhard rod
lower control arms etc etc
miscellaneous: passenger side power window motor, shox and struts. e brake shoes, slotted rotors and ceramic pads. time to make betsey fast as hell.
thanks if any way possible the closer to dallas texas the better im about 25 minutes north of there in aubrey texas. thanks.
prc 215cc heads.
fast 90/90 intake
42lb injectors
suspension:
aftermarket a arms
strut tower bar
panhard rod
ms4 cam.
prc 215cc heads.
fast 90/90 intake
42lb injectors
suspension:
aftermarket a arms
strut tower bar
panhard rod
prc 215cc heads.
fast 90/90 intake
42lb injectors
suspension:
aftermarket a arms
strut tower bar
panhard rod
These are my 2 threads:
https://ls1tech.com/forums/western-c...l#post11360551
https://ls1tech.com/forums/western-c...ome-parts.html
I've already sold my stb, Lower PHR (upper still available), SFCs, A arms, kmember, injectors and 100mm MAF.
If you are near Austin, I just checked a quote for someone for the moser.
Its was 113 for a business and 191 for a residence. but was cheaper to send it to NY or NC for some reason.
Thanks,
David
