pacesetter long tube e cutouts
Old 04-02-2009, 05:34 PM
94-z's Avatar
Default pacesetter long tube e cutouts
i have pacesetters long tubes sitting downstairs and am planing on e-cutouts true duels with h-pipe with quiet mufflers dumped rite before the rear end. My question is will it fit in the amount of room and what mufflers i should go with? Also cutouts before or after teh h pipe?
If you have pics and sounds clips they would also help alot. thanks
Old 04-02-2009, 06:16 PM
ss.slp.ls1's Avatar
I think the cutouts will work anywhere 18" and further past the H-pipe. Why not get a X-pipe? It will all fit, you might loose some ground clearance. Look into getting some Magnaflow bullet mufflers.
Old 04-02-2009, 06:34 PM
94-z's Avatar
Looking for a deeper sound with the h pipe as for mufflers arnt those loud I kinda want quiet sleeper unless I open the cutout car will have full bolt one with 4.10 gear
Old 04-02-2009, 06:36 PM
ss.slp.ls1's Avatar
It's going to be difficult to get TD's to sound like a sleeper. You could try putting two bullet mufflers in sequence on each pipe before the axle. Otherwise, get a y-pipe and a Magnaflow catback and install one cutout before the axle or two cutout's before the y-pipe merges.
Old 04-02-2009, 07:08 PM
94-z's Avatar
So besides bullets are there any other mufflers you. Guys would sugest?
Old 04-02-2009, 07:13 PM
ss.slp.ls1's Avatar
Well you could weld in standard style mufflers, but I don't know where they will fit before the axle.
Old 04-02-2009, 08:17 PM
IronOutlaw's Avatar
Any muffler you run in front of the axle is gonna be loud. my 1 chamber flowmasters didnt seem as loud as my spiral flows were.
If you want quiet get a catback, or go over/under the axle with some big turbo mufflers or something.
Old 04-02-2009, 08:40 PM
94-z's Avatar
I am not really looking for very quiet just sleeper- ish basicly I am trying to get the biggest difference between cutout open and closed
Old 04-03-2009, 11:28 AM
94Z28rag's Avatar
Not gonna happen with that setup.
That's only going to work if you get an ORY to a catback and put either dual cutouts on the y-pipe or a single on the i-pipe.
Quick Reply: pacesetter long tube e cutouts
