1 Bar MAP,2 Bar MAP,3 Bar MAP
Old 04-02-2009, 06:47 PM
B.Buster's Avatar
Default 1 Bar MAP,2 Bar MAP,3 Bar MAP
If my understanding is correct 1 bar is stock (no boost),2 bar goes to 9.2 boost and 3 bar goes to 14.7. Is it possible to use a boost MAP (GN or Typhoon MAP) with a stock F-body PCM and it read the boost? Thanks.
Old 04-02-2009, 08:52 PM
LS1TECH Sponsor
foff667's Avatar
2 bar goes to ~15psi, 3 bar goes to ~29psi.
-Bill
Old 04-02-2009, 09:15 PM
B.Buster's Avatar
Thanks Bill , is it possible to run 2 bar with stock 02 PCM ?
Old 04-03-2009, 08:15 AM
LS1TECH Sponsor
foff667's Avatar
Yes, however you will find it much easier to use one of our custom operating systems rather than the stock os.
Old 04-03-2009, 12:36 PM
Former Vendor - No longer Vendor
ArchetypeZ28's Avatar
You will have to flash the pcm to use a custom OS.
Part# 12223861 3bar MAP
Part# 16040609 2bar MAP
Part# 16137039 1bar MAP
Old 04-03-2009, 03:35 PM
B.Buster's Avatar
Could this flash be done with Edit ?
Old 04-03-2009, 03:50 PM
LS1Tech Sponsor
Rob@EFIAlchemy's Avatar
m not sure if edit give you that capability but i know efilive cos5 does
Old 04-03-2009, 06:22 PM
Frost's Avatar
no, you need HPTuners or EFILive.
