whats the biggest tire i can fit on stock 16 in rims
Old 04-02-2009, 07:49 PM
Smoke Em's Avatar
Default whats the biggest tire i can fit on stock 16 in rims
i got a 95 z28 with the stock 16 inch salad shooter rims on it
i was wondering what is the widest tire i can put on those rims as well as the tallest size
so the biggest tire i can put on stock 16in rims
i was also wondering if 02 17 in SS would fit right on no problem
Old 04-03-2009, 02:13 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Widest recommended is a 255/50/16
The 02 wheels will require a little "clearancing" where the axle hub goes into the wheel. The center hub is slightly larger on the LT1 cars. I had to do it when I put my 02 CETA wheels on my 94 Z28
Old 04-03-2009, 07:15 PM
'00_Z's Avatar
+1 on the 255s. You could go taller than a 50 series but it would look like sh*t.
Old 04-03-2009, 09:16 PM
fccs's Avatar
255/50/16 like said above is fine to run on the 16x8 wheels.
Old 04-09-2009, 11:36 AM
kmdracer's Avatar
I ran 255/50/16 Dunlop Sp5000's on my car when it was newer. Best all around tire I've ever had on the car! Checked Dunlop's website, apparently you can't buy them any more.
Quick Reply: whats the biggest tire i can fit on stock 16 in rims
