L92 Heads and Piston Valve Reliefs
Old 04-02-2009, 08:54 PM
sschoeffler's Avatar
Default L92 Heads and Piston Valve Reliefs
I was looking at my setup, and the valves are bigger than the valve reliefs in the pistons, and checked 2 different pistons. I checked a set of JE -29cc pistons and a set of Wiseco -8cc pistons and in both of them, the valve relief wasn't big enough to accommodate the big *** valve of the L92s. What is done to fix this, or am I just plain ignorant on this subject?
Old 04-02-2009, 09:46 PM
racer7088's Avatar
The Wisecos do fit if they are the newer ones. We use them all the time.
Old 04-02-2009, 09:47 PM
SweetS10V8's Avatar
You have to get pistons with l92 specific valve reliefs, or modify your own.
Old 04-02-2009, 10:30 PM
cam75w/ls1's Avatar
I had my Diamond pistons flycut for the L92's to reuse in the new build. Diamond has the L92 style pistons niow.
Old 04-03-2009, 11:17 AM
briannutter's Avatar
I think you've got some of the k394 series pistons. If they were made in late 2007 and later, they are Wiseco multifit valvepockets that accomodate the L92's and others. If the valve pocket looks perfectly round instead of slightly oval, you have some of our earlier parts. -Brian Nutter
Old 04-16-2009, 09:58 PM
Whats it cost to have them flycut by chance?
Old 04-21-2009, 09:15 AM
cam75w/ls1's Avatar
I'll have to check the reciept. I had other work done beside the reliefs. Will get back to you.
Old 04-22-2009, 11:02 PM
hookemdevils22's Avatar
i haven't found aftermarket pistons that can be used with the 6.098" stock rods - they're all for 6.125". correct me if i'm wrong here, please.
Old 04-23-2009, 10:20 AM
racer7088's Avatar
I am away from my catalogues but I think you have a few to choose from. Most do use the aftermarket rod though you are right but I have used a few that don't and stay with the stock rod and pin.
Old 04-23-2009, 10:33 AM
wiseco's will work with the stock 6.098" rods - they use the stock-size .927" pin. i guess it's helpful to use the telephone every once in a while...
EDIT: I'm sure others will as well (i'd verify first, of course), I only called wiseco.
Old 04-23-2009, 12:28 PM
You can use an aftermarket 6.098 rod with the .927 pin, but be prepared to deck the block some. Some blocks come short from the factory spec of 9.240, so it's pretty common for some of our customers to have to run the 6.098/6.100 stuff to make things work out.
Old 04-23-2009, 01:29 PM
Got ya - you'd need a deck height of 9.213" using the stock 6.098" rods to get to zero deck.
Old 04-24-2009, 10:52 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
The new Wiseco should be no problem, we stock those all the time.
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Quick Reply: L92 Heads and Piston Valve Reliefs
