How much nitrous can my LS2 hold?
8 second mod
my ls2 made about 800 or so on 2 stages. stock block. good rods and pistions.
id say your good to spray 150 as long as the tune is on target.
my stock ls1 with twin turbos made 600 for 30,000 miles i took it apart and it looked MINT!!
Guest
Posts: n/a
As long as you have adaqute fueling to support the Motor and Nitrous you should be fine. If you are running off the stock pump those are typically good for around 450-480rwhp from what we have seen. With you having headsd and cam I'd definately get it on a dyno ot motior the AFR...we typically like to see if at aroudn 11.4-11.8.
I had 75 jets in it and it made 530whp. My tuner told me the fueling was perfect and it showed no signs of being lean, other than when the nitrous initially hit. I do have a wideband. I ordered jets for a 125 shot so I think Ill just stick with that. Are these LS2's good to a certain hp?
8 second mod
