Would you keep the level 4 or...
Old 04-03-2009, 02:46 PM
Spellbound's Avatar
Default Would you keep the level 4 or...
My girlfriend has a RPM level four 4L60E that has worked flawlessly behind her 346, H/C, Z/28 that is now is getting a 427. So, should she sell it and upgrade, or take the chance that it will hold for awhile?
It will mostly be street driven with occasional strip use.
TIA
Old 04-03-2009, 02:53 PM
crzytown69's Avatar
dont fix it if it isnt broke
Old 04-03-2009, 04:17 PM
LS1Tech Sponsor
performabuilt's Avatar
If its in there and working, You already have a built unit , Check the fluid and filter if all is clear keep using it and if not send it back for a refresh I am sure they offer something like that.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-04-2009, 10:49 AM
FLT
FLT's Avatar
Contact TJ at RPM and tell him what you guys are doing. I'm sure they have an option for you. Vince
Old 04-04-2009, 03:15 PM
Avengeance's Avatar
TIA
Tell her to get that thing going cause this stock bottom end LS1 I have is coming for her.
Old 04-04-2009, 04:15 PM
tording99Z28's Avatar
If it sees limited track use and the Lvl 4 in it is not broke, then drop the pan and take a look at it, put some fresh fluid in and a new filter and let it rip. I bet it holds for a long time behind the 427.
