New LS1 Owners - Newbie Tech - How much oil w/ filter in LS-1??
1gt2nv
04-03-2009, 05:07 PM
I bought some m1 oil and a m1 filter. How much oil does a LS-1 take? I bought the car and there isn't a manual in the glove box. Thanks for the help and sorry for the newb question. :confused::confused:
oohtwo WS6
04-03-2009, 05:27 PM
6 quarts with filter
blakern
04-03-2009, 05:35 PM
I thought it was 5.5 with filter?
twitchtwice
04-03-2009, 05:39 PM
yeah its like 5.5 or 6, i got the bigger filter so it was a little more.
DlXlE
04-03-2009, 06:15 PM
For reference you can go to autozone's website and look up the amount of oil you vehicles engine needs for most vehicles. I had the same problem you have when I bought my Jeep.
ds98formula
04-03-2009, 06:33 PM
book says 5.5 quarts
1gt2nv
04-03-2009, 06:58 PM
Thanks guys. 5.5 it is then! Now I just have to get more oil. Bought 5 quarts.
outkast6991
04-03-2009, 07:01 PM
6 qts here for the last 6 years with no problems
99huggerorangeZ
04-03-2009, 08:13 PM
mobil 1 syn 5w30
short filter=5.5qts
tall filter=6.0qts-im running the tall wix
i have been doing that for 10 years no problems
iowackers
04-03-2009, 09:20 PM
Either 5.5 or 6. It depends on how long you wait for the oil to settle before you check it. When I worked at a Chevy dealer some guys would start up a car/truck. Let it run for 20 seconds, then immediately check the oil level. This is incorrect. You need to let it sit for at least 5 min. to let the oil in the valvetrain settle to the oil pan. I learned this the hard way after leaving GM and going to work for John Deere. A 12.5L diesel engine will hold 1-2 gallons of oil in the upper end for 2-5 min before it drains down. Now that is a little over full!!
99 ss
04-03-2009, 09:47 PM
will 5qts hurt it couse i put in a kan oil filter
Greg Pippin
04-03-2009, 09:51 PM
6qts of 10w30 non-synthetic mobil here, with the GM 46 filter.
waldershrek
04-03-2009, 09:52 PM
:confused:
SOMbitch
04-03-2009, 10:04 PM
5.5 is what my manual says but I run 6 because of all the bearing failures due to apparent oil starvation. I was reading some posts last week about guys running 7 who road race/A/X thier cars. That seems excessive to me me but maybe 6.5 would be fine and not have the crank kick up oil and aereoate it. That would seem like the biggest issue to me????
1gt2nv
04-04-2009, 10:49 AM
6 would be ok, but I'd think 7 would be a bit much. I put to much oil in a old truck I had and it smoked very bad. I'll try 5.5, let it sit for 20 min. If I need more I'll put in the half quart I'll have left. Thanks for the info guys. I have alot to learn about the great LS-1!!!
Z28/2002
04-04-2009, 11:20 AM
I run 6 quarts in my cars as well
mikenews
04-04-2009, 01:03 PM
You more oil you run the more power you will lose with oil drag on the crank. Yes minor, but just put what it is called out from the manufacture. The dipstick is also not calibrated. So with the proper size oil filter... it calls for 5.5 quarts.
thunderstruck507
04-04-2009, 03:00 PM
6 quarts
MonmouthCtyLS7
04-04-2009, 03:25 PM
5 1/2- 6
01SOMZ28
04-04-2009, 03:26 PM
5 1/2 quarts.
1gt2nv
04-05-2009, 07:00 PM
Well, that was easy! Changed the oil today. The only issue I had was that the filter was very very tight. I had to stick a screw driver in the filter to turn it. The oil was the worst oil I've ever seen in a car. Very dirty. I bought the car and haven't drove it yet. Waiting for the roads to get nice. Now the car has new oil and a new filter. Should run better. The woman I bought the car from had a tornado fuel saver in the stock lid tube. I found that out when I put the slp lid on. So I knew I had some work to do to the car. I think I saved a LS-1. Who knows how bad it might have got.lol
araber89
04-05-2009, 07:24 PM
i would say buy the cheapest oil possible then just fill it until it comes out the top of the filler neck. guaranteed 20,000 miles :D :D
TAtoad
04-05-2009, 07:32 PM
if you use the PF61 truck filter, 6 quarts even
TAtoad
04-05-2009, 07:38 PM
after 3-4k it might burn some oil, so just stick with the 6
FiredUpZ28
04-05-2009, 09:34 PM
I would be worried about smackin something with the bottom of the filter being lower than the pan and headers.
Z28/2002
04-06-2009, 03:21 AM
If you hit the oil filter then you got bigger problems to worry about
udienow
04-06-2009, 09:16 AM
I use the larger mobil 1 filter (M1-206) and with that I use 6 quarts of oil. Car is going to burn some oil anyway, so even with regular filter I would put 6 quarts.
hj99Z
04-06-2009, 09:21 AM
Actually i have already smacked a hole in one. Stray rock on the driveway, had to change the oil right there in the dirt.:bang:
qwk93ta
04-06-2009, 10:32 AM
I've always used six quarts.
the big d
04-07-2009, 09:52 PM
is the Gto oil pan different because I always use 6.5 quarts?
