Lifters???
You can pull the PCM fuse, remove the spark plugs, keep the TB open, and spin the engine with the starter. I don't know if that will even get it close enough to pumping up the lifters. It will however prime the crank at least. But the lifter will pump up quickly after initial start up.
if you soak them in a bucket of oil for a day or two they should be kinda close. but they have to be submerged. ive never done it. i usually just start the engine and run it a while then re adjust the valves when its hot. but thats what all the old school guys do.
