draglite 15x4 2.25 BS..spacer?
Old 04-04-2009, 05:21 PM
SMALLBLOCKHERO's Avatar
Default draglite 15x4 2.25 BS..spacer?
i bought the 2.25 bs cuz all the pics ive seen they look the best kinda tucked more then the 1.75 bs. did you guys use a spacer? how much grinding should i expect if i dont run one. i didnt try to fit them up yet, im still fitting the 15x8 rears. im just curious as to how your wheels fit and what i should expect.
Old 04-04-2009, 06:28 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I've got them on my CETA. I had to grind the calipers and I don't remember what size spacer I used
Old 04-04-2009, 09:13 PM
yeah i know,funny you responded. your car was one of the ones i was lookin at . i liked the stance, your fronts seemed tucked real nice. i wanted to not use spacers at all. im just hoping i can get away with not using them.
Old 04-05-2009, 03:39 PM
Z28/2002's Avatar
I really don't have a good picture showing the fronts but here are two.
and one of the caliper
Old 04-05-2009, 03:48 PM
oh man thanks. great pics. your tires are tucked perfectly. way more then a lot of other skinnys i see even wth the spacers.. it doesnt look like a lot of grinding on the fronts. i think i took off more on my rears then you did with the fronts...lol. you were able to use the stock studs and a spacer with the front? im amazed it fit, i got ARP longer studs for front and rear.
Old 04-05-2009, 05:08 PM
Z28/2002's Avatar
Yeah it still has the stock studs in the front but I'm putting ARPs in when I get back. I didn't grind anything on the rear because my pads are worn, I ran a 1/8" spacer on the rear with 3" ARP studs.
Old 04-05-2009, 08:44 PM
did you run the same size spacer on the front? i can see the pattern on the hub from one. thanks for all the help bro.
Old 04-06-2009, 03:47 AM
Z28/2002's Avatar
that pattern is from the stock wheels but yes I am running a spacer on the front. I think there are two 1/8" spacers but don't remember for sure
