F.a.s.t tb help
Old 04-04-2009, 06:40 PM
superchargedgp's Avatar
Red face F.a.s.t tb help
before you tell me to sell it, lets try to figure it out
i have fast 78mm TB it had a common sticking issue that most FAST tb's have. it wasn't bad but i was getting annoyed by it.
so i took it all apart including the shaft out of the body, to see if by adjusting the blade it would solve the problem. i put it all together and it seemed fine
now when i put it back on the car, when the car is off its smooth as butter doesn't hang up or stick, but when the car is on, if sticks bad, to the point that you have to physically slam it shot by turning the linkage. it seems like the vacuum is holding it open.
so who can help me?
THANKS GUYS!
Old 04-04-2009, 06:55 PM
WELL i took it apart again and i think i found my problem, the shaft was bent i dont know how but it was binding up the bearings
Old 04-05-2009, 02:41 PM
thunderstruck507's Avatar
whats funny is mine only sticks once its installed, its smooth when its off
Old 04-07-2009, 07:14 PM
UPDATE
after 60 miles no sticking at all, not even once. so i think that should solve the problem with the TB's
