flipped 94 lt1 exhaust manifolds leaking, where to get donuts?
Old 04-05-2009, 03:33 PM
miguelcg3's Avatar
Default flipped 94 lt1 exhaust manifolds leaking, where to get donuts?
Hi everyone
Im running flipped 94 lt1 manifolds for my turbo set up, I used generic 3 bolt cooper gaskets, but they are blown in 20 quarter ile pases. Should I use the stck donut and gaskets or have cooper gaskets mede like the lt1 flange?
Thanks
Old 04-05-2009, 06:18 PM
RealQuick's Avatar
You could just use red rtv... no gasket.
Old 04-05-2009, 09:46 PM
4SFEDZ's Avatar
got any pics of your setup? what kind of power you making? details on the build?
Old 04-05-2009, 09:55 PM
miguelcg3's Avatar
realquick... rtv wont cook when manifolds are glowing red?, by the way your great work inspired me to build the first lt1 turbo on Mexici..as far as I know.
4SFEDZ... I could test it on the track,just street racing.
Its a stock lt1 just with the tallest composite gaset I could found, at 5,6 psi I was beating ls1s with programming, headers and exhaust by a nose.
Old 04-05-2009, 11:15 PM
RealQuick's Avatar
Thanks .
glowing red huh? that doesnt sound good. Those mani's are thick... i don't think they should be glowing red. RTV probably won't hold then. I'd check your tune.
Old 04-05-2009, 11:48 PM
miguelcg3's Avatar
Well theyre not all over red, but after some pases I opened the hood and you could see them in a shade of red around the exhaust ports, My tune is safe around 12s Air fuel ratio... or should I go richer?
thanks
Old 04-06-2009, 08:47 AM
RealQuick's Avatar
12's for A/F... so 12.0 or 12.9 or in between? IMO that is is too lean. I'd go down to 11.0-11.5 on pump gas to be safe.
Old 04-06-2009, 09:07 AM
4SFEDZ's Avatar
ya i wouldnt go any leaner than 11.5, mine runnin around 10.7-10.9 lol!
Old 04-06-2009, 03:46 PM
miguelcg3's Avatar
thanks for your help guys
doesnt 10.5 AF ratio foul plugs?
Old 04-06-2009, 09:29 PM
4SFEDZ's Avatar
ya, mine is in the high 10's and it fouls them some, but id rather be safe than sorry!
Quick Reply: flipped 94 lt1 exhaust manifolds leaking, where to get donuts?
